Hello, how about it I have a Renault Clio 12oo yesterday I took it and with a bump I was drunk with the battery but I was on the road. I got the quarrel of Stop ABS and handbrake. When I get home it turns out that I had not squeezed the borna clamp well and squeezed her well. Once tight I take advantage and look at all levels and it's all right. But when they start they turn on the same lights. And the battery is new 1 month ago. Please someone knows what can happen.
Hello Federico, the stop light and handbrake turn on jointly with the engine running when brake fluid level, the ABS light can be a sensor if I grab a very large bump, or it can also be due to a tension peak when the battery terminal is disconnected with the battery terminal with the engine running, to verify the exposure of the ABS it is necessary
