Seat cordoba brakes TDI
12 years 7 months before #38982 by manual-mecanica
Seat Cordoba TDI brakes published by Manual-Mecanica
Well the first thing to greet all the foreros of this page. I have a small or big problem ... I'm not sure. Because it will be that my Seat Cordoba wears out the pill from outside the right side to butt while those of the left side and the interior remain in half use? Apart from that when I go to 120 km/h more or less if the strong brake vibrates the steering wheel? Well say that the albums were new put a year ago, Brenbo brand. Greetings to all and help x favor.
12 years 7 months before #39009 by manual-mecanica
Manual-Mecanica response on the topic Seat Cordoba TDI
Hello friend, check if the flexible of that wheel is not semi -trained, and that the caliper does not have the engraved or dirty embolo and prevents him from returning to his position, the almost certain vibration is for the praised albums, you will have to rectify them, tell us how you leave, greetings. :)
12 years 7 months before #39122 by manual-mecanica
Excuse me for this very late response but with good intentions to help good if that problem continues to review the alignment of the wheel this is probably the problem of all your misfortune.
12 years 6 months before #39286 by manual-mecanica
Hello friends, thanks for answering. To say that at the moment the Izd brake clamp disassembled in question and clean the embolos well and the entire clamp. The thing is very rare, since it wears out the side from outside to the iron when your partner on the engine side "say" is more or less like those on the other side. I hope I have solved it with this, but I will not know until 1,000 kilometers to see the difference that both have. If so it is not solved I will try everything you tell me. Greetings and I said thank you very much for your help.
