CHANGE DIESEL FILTER HILUX 2008
12 years 7 months before #39044 by manual-mecanica
CHANGE DIESEL FILTER HILUX 2008 Published by Manual-Mecanica
Good,
estimated. I write to know what kind of problem is being generated when changing the diesel filter of my Hilux 2008.
previous months I note that my engine went out after changing the diesel filter, I thought it was the entire prota filter and I bought it as an agency. The problem was solved.
I have not played the change of the diesel fitter and now the engine is turning off.
They have told me that I am not the only one that the engine is turned off after changing the diesel filter.
Can someone help me if I am jumping any or leaving something for done when changing the filter that makes the line take the air and turn off the engine.
Kind regards
12 years 7 months before #39097 by manual-mecanica
Manual-Mecanica response on the topic Diesel filter Hilux 2008
The only thing that must be taken into account when changing any oil filter is that at the time of putting the new one, it must be full of oil as well as revalsandoce and squeeze it well more.
12 years 6 months before #39169 by manual-mecanica
If it is a Hilux 2008, it is sure that you use the element filter only the paper part and it comes with some stamps or ring that I think you are installing badly and that is why it takes air I hope it helps you.
