Hello again, look with the theme of metals, wear is normal but I have you changed them with closed eyes, they are not so expensive, buy the same measure as you are using on one side of the metal appears if this STD (Standar) or ..25 / 0.50 etc.
These are the measures in which it was after a rectification but in case you doubt the sample and purchases, it is important that you look at the disassembly for assembly the notches of the metals. eye. That notches should be in the same place for example the connecting rod has the bag where the notch goes back the engine the connecting rod cover should also be in the same way. Only the surfaces are very clean place the metals and before the lubricating assembly a little with clean oil and torque torque plus 1/4 of rotation in silicone connecting to the carter and the engine together and ready (so that you have good the pieces with benzine or gasoline 93 oct. Greetings old
that you have bkn.
