Volkswagen problems with the change of cash)
12 years 6 months before #39576 by manual-mecanica
Volkswagen problems with the change of cash) published by Manual-Mecanica
I have a Volkswagen Jetta, it turns out that when changing for the first time (for wear) the clutch disc, the gear lever does not hook when the car is turned on, but it does when it is off
12 years 6 months before #39592 by manual-mecanica
What model is your jetta? ... Your clutch does not release the album enough, so it does not allow you to synchronize gears with the engine on ... this can cause another independent mechanism of the clutch ...
