Chevrolet S10 turns on the ABS light and does not turn off
12 years 6 months before #39633 by manual-mecanica
S10 MOD 2005 Sometimes the light of the ABS is set on and does not turn off does not do so, as I verify if the ABS is wrong
12 years 6 months before #39635 by manual-mecanica
Manual-Mecanica response on the topic Chevrolet S10 turns on the ABS light and does not turn off
The right thing is to use a scanner that has that function and monitor the ABS, this will let you know if it is a wheel sensor and that is --- sometimes it is only a matter of cleaning them and with that enough ... or if it is a breakdown in the ABS module ... greetings ... happy holidays!
12 years 6 months before #39637 by manual-mecanica
Good lt-zeta answer is what corresponds 100% greetings ...
