Citroen C5 is turned on as a fault witness
12 years 6 months before #39634 by manual-mecanica
Citroen C5 is turned on as a breakdown published by Manual-Mecanica
Citroen C5 The fault light is turned on and the P0238 Supercharging Sensor Code comes out, someone can tell me where this sensor carries.
Greetings and thank you very much.
12 years 6 months before #39638 by manual-mecanica
Manual-Mecanica Answer on the Citroen C5
P0238 Turbocharger Boost Circuit High Sensor
Check this with your turbo Make food measurements and pressures.
greetings.
