Peugeot 306 Turb
12 years 6 months before #39685 by manual-mecanica
Estimated: I have a problem !!! With my lady we have a Peugeot 306 1.9 Turbo Diesel, and three straps cuts in less than 30000 km, cut at 100000, then at 115000 and now at 123000, all this in a year, the two first decoup the mechanic the mechanic that was because it had been nailed and therefore the camshaft stopped and therefore the breakage, and this last one. They don't know what happened. The oil precion was controlled because the camshaft could grab and that is not that, the injection bomaba was verified and okay, because it could clabrce and thus cut the belt. Aguan pump is fine, tensioners are fine, I just observe that they move a mm or less laterally. This Vesse will change the pineapples of the camshaft, follow and injected pump. I don't know what to do is a car that is very good in general, and I do not want to have a solution, here nobody gets hot in Caul can be the cause, they are disagree, the coase do not happen because if, everything has a cause and an effect, because of the way of conducting, discard it, more careful eh swells guide that I do not. Without sudden recesses or accelerations, and it takes great care. Someone knows or has experience in this type of cars. Greetings and thanks.
