Sometimes does not start
12 years 5 months before #39984 by manual-mecanica
Sometimes does not start published by Manual-Mecanica
Hello friends foros I have a Hyundai Automatic Matrix Year 2010, two months ago more or less after working at all good one stops it and sometimes it does not start it let it cool perhaps half an hour and it works, once it does not fail more for several days. One day I had an hour and stopped alone, I start immediately, the last time after three hours it started again. Will it be the motor captor? As I try when the car is working since I have no other to try., I will appreciate the help
12 years 5 months before #39986 by manual-mecanica
Manual-Mecanica response on the subject sometimes does not start
Hello first you go the basic parts for example ... gasoline pump, gasoline filter, ignition coil, if the battery is correct, it has liquid inside properly, it is gasoline right? Notify me and I am telling you ...
12 years 5 months before #40001 by manual-mecanica
Hello, the truth is that it is Bencina. When I fail, I have neither spark nor beencina, the pump does not work or the coil will be something that is isolated a fuse captor etc.?
12 years 5 months before #40014 by manual-mecanica
For my part I think that the captor has nothing to do with you have no benzina, spark, coil does not work, the porblema is electric you have to go on the part of Jack, the ralter said! First: See if the battery works correctly, then the fuses if they are all correct, then fix you take out the hose where the benzine arrives to the carburetor (try to start SIRMPRE.
