I did the A/Ay test see if the electro goes out over the course since the temperature rises from 90 degrees to 100 degrees and I observe that the electrventillator does not go out and the temperature is maintained at 100 degrees. When the A/temperature turns off, it begins to descend up to 90 or 92 or so (very heat day). I did this test not walking but regulating at the door of my house after using it 30 minutes.
Another fact is to observe the temperature bulb and have some liquid in the thread part, I do not know if it is normal.
At no time is the Stop witness turned on.
The refrigerant is at its correct level. Wander brand yellow.
What I have left is that it is the thermostat or the covered radiator. What tests can I do to know what it is?
Another thing, when I turn off the car the electro also goes out, should not continue walking until the temperature is lowered to 90 degrees?
I attach some photos:
Bulbo with refrigerant liquid:
TEMPERATURE WITH A/A PURPOSE:
Radiator:
Thank you already for the help
