Hello, they could help me because I do not know where the rely of the Dodge Caravan electrventilator is located, I must change it because I stick together when I turn off the engine, the fans are on the fans, I only have to disconnect the battery and connect it several times and take off thanks the question is where the rely is
If the electrical system has not modified it, it brings a 4 -line module to the front in the bridge near the radiator, so it cannot be glued. If it had a relay it would be that someone modified the electrical system.
Thanks for your answer, I found it if it is the module was next to the box of the box with two exagonal head screws against a plastic, that is, under the air filter there I am now waiting for them to send it to me from the Federal Capital since here in Uruguay there is not thank you very much.
