The point is that the truck generates a noise in the front on the right wheel, the noise is a
squeak They rectified discs and are in good condition, they are not uneven and have a good thickness ...
the band and tension of the band ...
the pulleys of the aggravated motor accessories:
alternator
of the
compressor
The tensioner
with a engine on in neutral accelerates it to 4000 rpm and no noise occurs ... It is not the engine therefore, therefore,
the vehicle is already in motion. Noise ... Try to check the wheel of the wheel to lubricate it and see what happened but this assembly together with the ABS indicator ... With this piece I have doubt.
Something tells me that it is the transmission but I cannot imagine what component it could be, I have the manual and according to what I see is that it brings an intermediate round between the transmission axis and the traction arrow within the same transmission, but I need to hear advice ... If someone has experience in this truck I thank you for your advice ... greetings ...
