VW Frio failure
12 years 4 months before #40568 by manual-mecanica
VW Frio failure published by Manual-Mecanica
I have a VW Golf 1.8 GL Mod.99
and the problem is that when it starts it to the maniana failure, because of the cold.
I would like to know someone someone has a possible solution.
I clarif
12 years 4 months before #40598 by manual-mecanica
Manual-Mecanica Response on the VW subject Frio Failure
It will be necessary to connect a scanner and check that the injection pulse has the correct amplitude, check the temperature sensor value, sometimes they occur like this to put unlikely spark plugs.
12 years 4 months before #40602 by manual-mecanica
Czech the temperature vulvo in addition to thermostat
12 years 4 months before #40673 by manual-mecanica
The temperature sensor may be as a drowned and you have a ignition problem like pizar thoroughly so that the acela is started or pump
