Renault 11 starter
12 years 4 months before #40575 by manual-mecanica
Renault 11 starter published by Manual-Mecanica
hello ..queria consult if anyone knows why reason faults the start (noise of crown and driving tooth safe) taking into account that I put new driver and crown. Since thank you (I don't want to risk buying a wrong spare one)
12 years 4 months before #40597 by manual-mecanica
Manual-Mecanica Response on the Renault 11 starting
The most caused thing is that the teeth of the teeth (inertia steering wheel) are worn and/or broken so they do not gender, remove the starter engine and with the help of a mirror through the hole where the engine is mounted, verify that the teeth are in good condition.
12 years 4 months before #40644 by manual-mecanica
This new changed it at the same time that I put the new driver .... also put a new clutch ... That is my confusion that the dentated parts that have to engage in the start of the starting are new ...
12 years 4 months before #40646 by manual-mecanica
Hello, so, if the bles are the right one, it can also be the fork or the automatic that the blessed do not push well and escapes why it does not enter well
