My Nissan Cabstar does not start
12 years 4 months before #40640 by manual-mecanica
My Nissan Cabstar does not start published by Manual-Mecanica
My Nissan Cabstar does not start even though I have put the new battery, because it has the failure as if I had no battery, but once started (tweezers or pushing) after a while it does not fail again. although sometimes it seems that it does not start with the joy it should.
12 years 4 months before #40656 by manual-mecanica
Manual-Mecanica Answer on the topic my Nissan Cabstar does not start
A test that you can turn off the vehicle measure with voltimeter the battery Example: 12.86 and in 1 hour without having started the battery again. If you see that at a lot of example: 12,22 is why you have a consumer example: when you close the trunk the light is still on and the battery spends.
Another issue would be that the starter has spent brobillas, it does not do it to beam and starts without force
12 years 4 months before #40675 by manual-mecanica
Thank you, I don't know how the forum works, but I prefer to give you the graduates twice than not to do it.
Salu2
