Honda Acor of 82 Urgent Help
12 years 3 months before #40730 by manual-mecanica
Honda Acor of 82 Urgent Help Published by Manual-Mecanica
Hello friends of this forum I need your help urgent what happens is disassembled the springs of the valve without realizing it and the height of the springs is unequal one is more under the other is the higher the question is it ???? Which of the springs is of admission and which is of escape .... because I do not find the height of the valves are even does not have the difference
I will appreciate it a lot.
12 years 3 months before #40739 by manual-mecanica
Manual-Mecanica Answer on the Honda Acor theme 82 Urgent Help
In the papers I will put you type motor, I say it why it may be that several models mount that engine and even other selling brands. And with that type of engine you go to the manual zone and look at Honda manuals of explodes and there are really in the display which are admission and which escapes.
Or putting the engine type the same, it comes out that other models or manufacturers assemble it and then look for a exploded manual of those others that are put.
12 years 3 months before #40741 by manual-mecanica
I looked at something. The Honda Prelude of that year with A18A1 and A20A3 engine carries a single camshaft and the exhaust valve is the one that carries the largest spring with another small one inside and the admission carries a shorter dock.
I hope this is what I put on you.
Click on thanks if you help you:)
12 years 3 months before #40753 by manual-mecanica
Thanks friend anyway,
it is a non -motor sling el161 and I can't find the manual
