Ford Ranger 2.8 TDI Power Stroke
12 years 2 months before #41111 by manual-mecanica
Ford Ranger 2.8 TDI Power Stroke published by Manual-Mecanica
Friends, I have a problem, I can't locate where the ECU of Ranger 2.8 TDI (Power Stroke engine) is installed. It is urgent to know where it is, since I need to perform a maintenance and cleaning work of the connection pins. Any help will be crapped. hugs.-
12 years 2 months before - 12 years 2 months before #41112 by manual-mecanica
Manual-Mecanica Answer on the topic Ford Ranger 2.8 TDI Power Stroke
[Attachment: 1] Motor-of-For
d
Hello, the Ranger 2.8 does not have ECU, it has a totally conventional rotary pump, the only thing it has is an electro stop valve located in the injection pump, it has a cable that gives a 12V current to the electro valve when the truck is in contact or start, and when one closes the contact short the current so that the engine stops. If this were a Ranger 3.0, it has a Common Rail Siemens system and the ECU is in the vain motor, attached to the short fire on the right side and has 3 chips with very fine pins. See attached file
Latest edition: 12 years 2 months before by .
11 years 2 months before #45917 by manual-mecanica
Hello someone would have the Ford Ranger Motor Manual 2.8 International Maxion Motor, to make an adjustment
thanks
