It does not work 2 ° Cylinder
12 years 2 months before #41464 by manual-mecanica
Manual-Mecanica response on the subject does not work 2 ° cylinder
I suppose you have tried to change the injector of the 2nd cylinder for that of the third, for example, to see if something changes?
12 years 2 months before #41468 by manual-mecanica
Let's see
has compression how much?
They regulated valves?
The injector works if
it receives injection pulse in the plug or connector corresponding to the injector 2? Wheel to test injection pulse .... Disconnect the OK injector connector
in the connector places an LED and that another person will start, at that time the LED has to turn on the LED
the circuit or line is fine, in case you do not turn on you have problems, mandatory workshop.
Check or change the jebe or rubber rings of the injector
both
from the
bottom
and upper Capital letters is that I am without glasses at this time Sorry
