- Thanks received: 1
06-19-2025 Hits: 800 Technology
Thank you, I realize it so let the water pump but I do not turn to take it out and I could not if there is any special way to remove it, it would be appreciated thanks for your help14982CA wrote: The time strap can be tensioning the water pump and turning it, I hope this detail serves you.
A MILLON THANKS MEN VERY CLEAR YOUR EXPLANATION I MAKE VERY CLEAR I WILL MA
Hello
I know what you are
talking about . By Lantanto he continues to throw the neck strap so strong as to move the crankshaft then take it to the gear or toothed wheel. Without placing it by compartment if not rather present it by supporting the tooth 3/4 parts of the width of the belt, do not worry to put it completely because you will not be able to with your strength, do not force it with levers that you can break it.
5. Now with a suitable dice and bar the crankshaft nut (below) turn to the side of the camshaft to put, ask someone to help you move the crankshaft while you avoid that the strap from the cam select time turns with the dice always down to completely accommodate the belt on the teeth of camshaft.
I hope it helps you, try to explain my best.
blessings.
