Radiator change
12 years 4 weeks before #41923 by manual-mecanica
Radiator Change Published by Manual-Mecanica
I want to adapt another radiator to a Datsun 1500 0 620 truck. I want to put a thinner radiator, such as half of the diameter that the original will have this change ???
I would like to know before sending me some muddy.
Greetings
12 years 4 weeks before #41927 by manual-mecanica
Manual-Mecanica Response on the Radiator Change
When the thermostat breaks the plug of the Spaniard bottle jumps the emergency insurance and throws the water and the same more or less when the radiator is ostrulle. If the water does not flul at the speed that you should create a pressure sceso in a part of the circuit and insurance you will rebound some sleeve in the long run.
Find a radiator that has the more or less similar pass tubes.
If the radiator is smaller the fan will be on longer.
