Subaru Impreza
12 years 3 weeks before #42043 by manual-mecanica
Subaru Impreza published by Manual-Mecanica
A cordial greetings friends, I have a request for help, I tell you, I have a subaru Impreza 1.6 year 1996 the engine adjustment all new everything but I looked like the hydraulic taques ... According to a friend he told me to put a 20W-50 Mobil oil to load the tques but currently it is currently with 10W-40 mobile and I really do not really do not do better or which they recommend for a engine of these newly adjusted. Thank you very much
12 years 2 weeks before - 12 years 2 weeks before #42049 by manual-mecanica
Manual-Mecanica Response on the subject Subaru Impreza
Use a 15W40 oil since if you put it heavier it becomes more difficult than penetrating the small holes of the tachies when the oil is cold.
Latest edition: 12 years 2 weeks before for .
12 years 2 weeks before #42055 by manual-mecanica
Brother The viscosity varies a lot between marks I would tell you that the you get them and the loads manually outside, if they are discharged when it turns again, it is necessary to make sure that it is raising oil pressure to the cylinder head (that the car on it turns it on turns off the light witness of the oil does not mean that it is lubricating well in the cylinder head) If the engine is all rectified frequently done, never Jamaas placed it.
