Nessite helps with my sunfare is model 99 The engine is 2.4 twin cam throws oil through the rod but the strangest thing is that when the air flow censor disconnect stops throwing and thus walks Vien for a month and then Buelve to throw
Take a test, assuming you have the oil at the optimal level, you can see it in the rod. Do you remove the oil plug and see if you snort a lot of air through ahy.
You may have the piston segments glued and you are throwing the compression into the carter, that's why I think you throw the oil where you can. ESO O COLATA WITH GRIDE THAT MAKES YOU EXHAUST GASES IN THE BLOCK.
