A/C CORDOBA98
12 years 4 days before #42248 by manual-mecanica
A/C CORDOBA98 Published by Manual-Mecanica
hello everyone. I have a problem with the A/C of the Cordoba of my wife 98. It has always worked perfect, the best of the car, but for a month it does not cool. I explain: Compressor works perfect, there are no leaks, I have loaded it, emptied and re -loaded, changed type of gas .... but it does not cool. The one who charged me gave up and told me that it could be a blocked valve because the pressure should have risen to 15 bar but did not pass at any time of 6/7 bar.
There if any phenomenon can give me a hand because there is not the thing to change the car.
Thank you. All the best
12 years 4 days before #42250 by manual-mecanica
Manual-Mecanica Response on topic A/C Cordoba98
That circuit is echo for gas R139, if you put another one will not work for you.
If you are tested with another gas: I understand that it makes reasons in the gums and together and something can be fuck.
Then the oil is not miscible <- to the Castilian who cannot be mixed with others. And apart it is an oil that is to the air you have <-It does not know or enters you or some of that, I do not remember well.
SOLUTION: You need to inert the circuit.
1º-Hacos Vacio.
2º-Metes Elio> Elio what he does is a varrid of everything.
3º-Hacos Vacio.
4th
5º-Metes Oil for systems R139 10 milliliters <-Ponle dye if you think there may be a small leak.
6º-is very important that you look that compressor brand has your circuit, because it depends on the compressor brand in the grams of gas puts you (example: Bosch 750, Lucas 800, the 350 duck). R139
The roll is that the A/C has a bulb stuffed with R139 if you put another does not open the bulb and the air no longer goes.
12 years 4 days before #42252 by manual-mecanica
Now that I think about it, of course what you have broken is the bulb,
it is an aluminum block that passes 2 tubes per in medium and carries a ball on one side of the aluminum block.
