(ESP): Do you carry key to disconnect it? <-the same is a bit bad and abeces flashes you.
If not, the ESP depends on the captors that are in the 4 wheels a cable that ends at the omocinetic tip next to the brake disc, 1st that the phonic wheel is clean that the collector is clean and without the cable peeled or anything.
2nd In the close handbrake you must have the lateral displacement sensor.
3º The acceleration sensor that often depends the car takes it on the velocimetro and is already.
What I aria once clean all the phonic wheels, if the failure follows the clabija of the displacement sensor and put a resistance of 0.3 omios from end to cable to remove that sensor closing the circuit with the resistance.
If the failure is already eliminated, you know the failure was the displacement sensor.
