Turn off Ford Transit 06 -.....
12 years 2 days before #42281 by manual-mecanica
Turn off Ford Transit 06 -.................. Published by Manual-Mecanica
Hello everyone.
I have removed the relay No. 15, which is that of day conduction light, connects the crossroads, but the position lights are lit, and I would like to connect them to my liking, not when I contact, as it does so far, can anyone help me, and tell me how I can do it? or pass the electrical scheme.
All the best
12 years 1 day before #42293 by manual-mecanica
Manual-Mecanica response on the subject Turn off Ford Transit 06 -.....
Do not remove relays, you go to the fuses and there is that light is position, cross or whatever you want from there you take cables and pass through switches and already mount your light fair as you want.
12 years 10 hours before #42300 by manual-mecanica
Hello, thank you very much for the answer, but maybe I have not expressed myself well.
I am holding an AC, mounted on Ford Transit, manufactured in 2009, and enrolled in 2010, it is German and Turkish. My wife and I liped the blanket at the head and planted near Colonia, and we brought it on; As you know for the countries of the north, the daytime driving light is almost law; In the Ford Transit 2006- ……, they solved the problem with a relay, No. 15, which as soon as I contact, light the crossroads. The position are also lit, the fact is that I am tired of starting the car with an extra battery charge, so I have removed the relay, the crossroads are no longer lit when I give contact, but if the position of position ……………?
My question as you can appear, is to ask you, anyone knows, where is the automatic ignition position lights act?, Or could anyone facilitate the electrical scheme?
Greetings and thank you very much.
