Try the coil, sometimes they are tristed and stones current intensity The injectors must reach a rich signal if this is weakened, this can happen to you and if you do not check the distribution point for the year of the vehicle they tend to deteriorate the tensioner of the belt and this causes the point to skip ... Try with that something similar happened to me and it was the point.
