Fugging in the carter Hyundai Terracan 2.9 4x4 2006
12 years 3 weeks before #42481 by manual-mecanica
Friends I have a leak in the carter, the vehicle is Hyundai Terracan 2006 and 4x4, the mechanic tells me that the engine must be removed to seal the carter, since it does not leave the front transmission system there is another possibility not to take out the engine and apply the silicon.
12 years 2 weeks before #42494 by manual-mecanica
Manual-Mecanica response on the escape theme in the carter Hyundai Terracan 2.9 4x4 2006
Good compa, unfortunately the Terracan Biene as most of the new vehicles with Factory Silicon, by the shape of the motor carter the same paste against the front differential with what or remove the engine or remove the differential. The engine is playing and you change the rear crankshaft retainer. Greetings.
