MY FIAT TYPE VEHICLE FAVES YOGAGA
12 years 1 week before #42508 by manual-mecanica
Good afternoon I have a fiat one Type engine 1.6 year 94 and the minimum sometimes is drowned and it has it normal and sometimes in 5. Sometimes also boot explosions through the exhaust tube I do not know if it is bumping also thanks and I await an answer soon.
12 years 1 week before #42524 by manual-mecanica
Manual-Mecanica Answer on the subject MY FIAT VEHICLE TYPE 1994
First check the time
check distributor and coil. let me know
12 years 1 week before #42529 by manual-mecanica
Thank you very much for the information but my car has no distributor and the ignition coil is new and a question how do you know the time or strap ??? And how do I know if you are damaged thanks I wait for your answer
12 years 1 week before #42530 by manual-mecanica
The belt is at the front of the engine. Locate in front of the pulley. There is a lid under that is the run
verifies that the points are well
12 years 1 week before #42532 by manual-mecanica
Friend, check the spark plugs. If you have time that you change it, there can be the fault.
