Corolla CE121 Motor 3C Electron Motor
11 years 11 months before #42551 by manual-mecanica
Corolla CE121 Motor 3C Electron Publish Motor Published by Manual-Mecanica
Hello friends, I need help with a C3121 year corolla 2001 Motor 3CE with electric accelerator and pump.
The problem is as follows, it does not have to stop as if the fuel pressure had low.
Chekee and I am error P1405 Turbo pressure sensor circuit.
In history I appeared to me P1222 (0.1,12,22) Refer to Related Manual.
Delete all the mistakes and reappear P1405
changed the piece for another, but of another model
You can help me, or get the electrical diagram of the vehicle.
thank you.
11 years 11 months before #42557 by manual-mecanica
You remove the turbo hose, you clean it, come out oil and everything, clean the rod that the furnaces has several times to let go, you follow the turbo hose you will see a sensor. If you have oil, you clean it. Current removes +,-
you delete the error and step on him that he is sure.
The ruling is that the variable geometry of the turbo is blocked for oil or dirt and having a pressure sceso the vehicle is put in a fault mode so as not to rewind.
The turbo carries a fine tube that goes to depression, but you step more, look that the tube is good.
11 years 11 months before #42581 by manual-mecanica
Thanks for the answer only that my vehicle has no turbo. This sensor is located next to the air treatment plant where the air filter carries. And what this sensor does is measure the suction or pressure pressure. Through a hose that goes in the treatment plant to the sensor.
according to the test with my multimeter.
I tried it in
1000 rpm
2000 rpm
3000 rpm
With the vehicle without weight (without moving)
and gave these values ​​that we see in the images.
I am translating a manual for it is 3C-e engine that is in Russian. In case someone has in English or Spanish I would appreciate.
greetings.
Diego Franco
11 years 11 months before #42606 by manual-mecanica
I tell you, don't look at the code because you put what it was. It is not about that, that code is telling you that you clean the EGR that is stuck from Ollin and the car does not regulate.
If for whatever it is, the EGR looks at the NTC of air temperature.
You already tell us something:)
11 years 5 months before #44867 by manual-mecanica
good afternoon everyone!!!
I tell you that this time solve the problem with a pump maintenance and change a piece. I confirm later.
I spend something funny.
I had a problem this week a small fire with my electrical part of the computer. I had to change my cables and computer. And after that I became the
P1222 Code (1,12,22) Only that now the vehicle seems out of the pump. Test in a pump advance sensor, and rider sensor. And nothing happened.
After looking for a lot on the Internet, which means I see the forum that believes myself. Jeejeje
Well tomorrow I see the bomb to see if there is an improvement and tell you later.
greetings.
My email
