Hello my problem is that my mitsubishi galant is 2000 2.4 Lt when a low cost to 40mph goes up and it feels that you want to turn off, in the plain if I am very detained when starting you want to turn off (as you drowned). I change the oxygen sensor, the Catalitical, the spark plugs, clean the injectors, change the gasoline filter, the Valve PCV, the EGR Valve, the air filter. I really don't know what the problem is. The car uses it to work and it is two hours to go and two to turn to my house. The maintenance of oil change is always a day. If someone can help me, I appreciate it with a heart. Thank you very much and good day.
