Consult Astra Dti
11 years 11 months before #42639 by manual-mecanica
Astra DTI consultation published by Manual-Mecanica
Hello friends, I need help with my astra 2.0 DTI (ECOTEC Motor), it happens that a yellow light witness has been lit on the board, which shows a rectangular figure (as if it were a water deposit) with a symbol that looks like a fan inside. I look at the vehicle manual and that fair is not clarified. My problem is knowing what it indicates, in order to verify where the fault is. Thank you very much.-
11 years 11 months before #42663 by manual-mecanica
Manual-Mecanica Response on the subject Astra Dt
It is warning you of a problem in the cooling system, electrventilator that does not drive lack of refrigerant fluid etc.
11 years 10 months before #42718 by manual-mecanica
Hello friends, a few days ago, see for a problem on my astra dti, (Light of the board on), jal helped me clarifying that I was indicating a failure in the refrigeration circuit (electro that does not work or liquid level). The point is that, the electro works perfect, the refrigerant liquid is at the level, there are no burned fuses .. In Finn ..... Check everything that my understanding may have to do and the light still is still on ... (only when it is in contact, as soon as it starts it goes out). The issue is that never before that and I want him to be as before, and apart, I plan to travel and I want to do it safely. Thanks for any suggestion ... greetings
11 years 10 months before #42719 by manual-mecanica
You can do the following, you take out the picture you open it and where the bulb goes you put some black insulating tape, you no longer see the light hehehehe. .
It's a joke, put a photo of the light that you say or look for someone who has a scanner and tells you what it is.
11 years 10 months before #42730 by manual-mecanica
Good, I don't know if you will have already proven it, but it may be the water expansion bottle sensor that works badly. The car can be working perfectly, this is fine, and the sensor is annoying. They put the computer.
