My fiat type 1600 fails like a horse
11 years 10 months before #42674 by manual-mecanica
My fiat type 1600 fails as a horse published by Manual-Mecanica
Hello, I would like to know if someone can help me I have a fiat type 1600 year 94 I had faults such as (I bounced the compression, oil in the last, the minimum bad and bounced explosions for you exhaust tube) also in the climbs it drown does not want to walk and turn off, now it changes the oil the oil changed the kid of the carburetor the gasoline filter the sparkles It can be someone who helps me for thank you good afternoon.
11 years 10 months before #42676 by manual-mecanica
Manual-Mecanica Answer on the subject My Fiat Type 1600 Falla does like a horse
It seems that you have a blank package or bad head. By chance do the vehicle gets white smoke for the escape? Is it overheat? Consume the cool liquid (coolant)? Disconnect the breathing hoses of the head cover and the oil plug to inspect if oil with coolant is combined; Its appearance is beige and milky consistency. You can also try with clean carburetor between the head of the head and the block there if the car revolutionizes. That would indicate that your packaging lost the seal and there is air entrance.
If you believe that the problem is not the head packaging, testing sprinkling cleaning between the admission manifest and the head and see if the engine revolutionizes; That will tell you that you have air entrance where the packaging between the manifest and the head lost the seal. It is also possible that you have broken motor sucking hoses; They usually harden and break producing air entry to the engine.
Below put some reference images regarding the appearance of cylinder head failure.
11 years 10 months before #42677 by manual-mecanica
Friend does not overheat, neither does white smoke boot through the exhaust tube in line general does not boot smoke, I changed the kid carburetor thinking that with this it could be solved and try it and follow a fault I get slow in the climb and go up as forced, I made change of spark plugs and kid of the carburetor with change of oil and filter thinking that it was the solution but it follows the fault in which you can help me. Here I attach the vehicle engine to see if you can help me thanks I wait for your prompt response.
11 years 10 months before #42679 by manual-mecanica
Ask, before the problem starts, do you stay without gas the vehicle? When reading your previous post and the one now noticed that I do not take into account that it is carbaded and has a distributor. I have three possibilities: it may be that your carburetor is covered; The causes could be left without gas or dirty filter. Question, did you completely mouth the carburetor stirring each part as injection needles and pressure control? Did you clean all the carburetor ducts? You changed the filter or fuel filters (there are vehicles that bring more than one).
The other, that the carburetor float is ruined and the carburetor is exceeding gas and is drowning the engine. Ask, you checked the spark plugs if they are wet; That would indicate that the engine is drowning in fuel.
The third, it may be that you have the rotor and the lid of the bad distributor; It may also be that you have bad the cables from the distributor to the spark plugs. From experience, tube a beetle with modern ignition; The engine started but had no strength to go out in plain; Change spark plugs, new kit and carburetor cleaning, and change cables. Nothing worked. The problem was the lid and rotor of the distributor.
Check those issues and if you already did we will see that other possibilities can be for your problem.
11 years 10 months before #42680 by manual-mecanica
Ok I told you the carburetor Kid, a mechanical friend was changed and according to his work, he told me that the carburetor was good and I think that if he did what the carburetor comments, he looks cleaned now as the gas you tell me, I don't know it may not be because if not the mechanic was told, the spark plugs are not wet x now they are working well, and what you tell me about the distributor if I do not review it. The car in a parking lot but that would be electricity failures? And of electricity I do not think it is the problem when he walks as a horse in ugly paper as a palante and back and drowns the mechanical thing when I changed the kid the car had 2 fuel filters and he told me that I damaged them eliminated and placed only one new and I no longer know if this is well thanks for the help I wait
