MAF NISSAN SENSOR 2003
11 years 10 months before #42724 by manual-mecanica
2003 Nissan Sentra Maf Sensor published by Manual-Mecanica
Hello, I have a problem with a Nissan Sentra GXE year 2003 with a QG18 engine, it turns out that the engine loses power generating me fault codes P0102 regarding the IAT sensor, and P0113 regarding the MAF sensor. My question is you can check this sensor to see if it is actually damaged because its cost is high.
The carraca car with a small failure after it earns a little temperature only achieves that it accelerates at 2500rpm by giving it more as it is stuck and turned off. Some suggestion was appreciated in advance
11 years 10 months before #42731 by manual-mecanica
Manual-Mecanica response on the subject Maf Nissan Sentra 2003
Search in the manual directory. There is a file called "Electricity Manual for Electromechanics."
11 years 10 months before #42735 by manual-mecanica
If you have knowledge, you can check the voltages of the Earth Pole sensor and the sensor signal generation for this is 1.3va 1.7V minimal if everything is okay has to do with live data with the scanner to be sure that the vehicle's ECU is receiving the sensor data.
11 years 10 months before #42736 by manual-mecanica
Hi Sorto73, unfortunately my self -destroy program spoils to tell you what the medication values ​​are, beforehand I tell you that you need a multimeter ... well I hope I do not go crazy with so much information in advance the Scaner I tell you which sensors cause that failure in the flow and by default they give you those codes 1-culan codes 2-Max Sensor and 3-the same caudalimetro that is usually. Try to turn the car with the flow disconnected and first of all look at a suction hose that uses the max sensor or sensor, the air dough measures.
11 years 10 months before #42741 by manual-mecanica
I think I have that sensor send me more photos of the Q is in the air cleaners
