CYLINDROS COVER ADJUSTMENT 405 TURBO DIESEL
11 years 10 months before #42810 by manual-mecanica
Setting Cylinder Cover 405 Turbo Diesel published by Manual-Mecanica
I have a consultation, it is the first turbo diesel that I do, and when I adjust the lid by degrees as it corresponds, it seems that I will cut screws, I clarify
1 are new screws that says not to lubricate
2 Di 6kg and the next 90º and with that I already gave it as 20kg
3 still the second adjusted of 90º still is missing.
How are I afraid of cutting screws and that I get expensive, I ask, approximately how many kg fit? I still give you confident?
11 years 10 months before #42819 by manual-mecanica
Manual-Mecanica Answer on the topic Cylinder Cover 405 Turbo Diesel
Diesel engines need much tightening, if the screws are new, put what puts you without fear.
11 years 10 months before #42822 by manual-mecanica
Thank you, today I finished adjusting, it is incredible, compared to the old material excellent material, the indenor gives 8kg that carries and safat the threads, this motor is banked as 25 or 30 kg, a luxury, greetings and thanks.
