Failure Code P0715 Hyundai Santa Fe v6
11 years 11 months before #42987 by manual-mecanica
FAULT CODE P0715 HYUNDAI SANTA FE V6 Published by Manual-Mecanica
Hello, I have a P0715 fault code (Malo functioning in the input / turbine speed sensor circuit) is a Hyundai Santa Fe 2001 V6 V6 G6BA motor (2.7).
As I solve the problem I check and where I place this sensor is automatic box in advance thanks.
11 years 11 months before #42994 by manual-mecanica
Manual-Mecanica Response on the subject P0715 Hyundai Santa Fe V6 Failure Code
The sensor is above the passee I have the diagrams for what you see the colors of the cables because according to your code the fault is the sirchite of the cables you give me your address to send them
