Kangoo 1.5 dci mod 2008
11 years 9 months before #43150 by manual-mecanica
Kangoo 1.5 DCI Mod 2008 published by Manual-Mecanica
Hi, I have a Kangoo with more or less 70 thousand km, the point is that the veículo was walking in perfect condition without any failure even at the time I stop and I don't start anymore.
The veículo was diagnosed and no memory failures were found, all kinds of relements and fuses were reviewed, but what is noticed is that when you go the high pressure pump does not send gas oíl towards the injectors by any of the pipes. If someone has happened to him or something similar would be grateful for his help.
11 years 9 months before #43153 by manual-mecanica
Manual-Mecanica Response on the Kangoo 1.5 DCI Mod 2008
Hello Maurocar,
I tell you that if you have a diagnostic equipment, the first thing is to connect it and go to data flow to see if the steering wheel sensor is giving you rpm at the time of starting between approximately 170 and 200 rpm, because if you do not have rpm the injection is not enabled, anything to your dispute
a greeting Sergio
11 years 9 months before #43159 by manual-mecanica
We are softening that you have a mechanical diesel pump that feeds a cylinder to 1050 pressure bar.
You will have a pressure sensor in the comon-ray cylinder or in the pump, try to release or bridge it in case you are denying that sensor.
Release the tube and if the pump does not throw anything when you start, look to see if there is any broken tube that is downloading the circuit or see if the low pump is broken and does not give you the high one.
Diesel vehicles are simple if it has diesel and tour starts. <-That if it is well synchronized from distribution.
