MY GOLF 2.0 YEAR 97 went out and do not want to turn on I have a spark of the coil and the gasoline pump sends but does not turn on ... what is causing me fault ????? could give me some idea what the problem is ..
Hi Edisonh, have you already checked if there are pulses in the injectors? If you did not jump or burst the distribution band? Or give me more information about how the fault was given.
Ok the fault was on the road and the car was left without force as if gasoline were not arriving, I checked if they were in time and then discarded the gasoline pump and the coil, and a month ago I send him to clean the injectors and they were fine. Now I don't understand why that fault .. ??? GIVE HELD MORE DOES NOT START THE ENGINE ..
