Good I have an inconvenience with a Citroen C4 fails when it goes on the route heads and runs out of power
and it gave me the following P0106 failures, P0300, P0301, P0302, P0303, P0304,
Miprégunta is the following can the MAP sensor generate the other failures in the cylinders since the fault that refers to the MAP is Sensor, control the wiring, the feeds are correct and the signal also in the city does not fail if it does when it travels en route, I thank you for any contribution
for the doubts I change the spark plugs, I needed them, I needed them 53000 km
