Doubt Compatibility Renaul F9Q engines
11 years 8 months before #43555 by manual-mecanica
Doubt Compatibility Renaul F9Q engines published by Manual-Mecanica
Hello to everyone, first that nothing, I have bought a vivaro dci 100 with the engine broken, so as not to complicate it I am going to put a scrapping engine, the doubt my engine is F9Q 760, as I understand those of Laguna 120 cv F9q 750, they serve him and now comes the last turn The one of the lagoon but has different letters f9a, this engine is mounted by the great Scenic, does anyone know if it is the same as the F9Q? Thank you
11 years 8 months before #43559 by manual-mecanica
Manual-Mecanica Response On the subject Doubt Compatibility Renaul F9Q Motors
Do not complicate yourself to scrapping with the papers and give you the same engine according to reference.
If you do not do it: sensors and switchboard <-problemas.
gearbox and marches <-problemas.
In the motor block there are 2 numerations of the serial number and the motor type if the motor type is not the same.
In your case at the exit of gases you have a probe that is set to receive the 90CV gases you put the gases of 120cv and the switchboard leaves you the vehicle limited to 2000 rpm in failure mode, because it recognizes it as an error record.
I hope you serve the explication.
11 years 8 months before #43615 by manual-mecanica
I am risking, I have been looking and the block is very similar the high pump has the same reference, not the injectors, the two are six marches, the turbo and the admission manifold
change, having what happens. . . but I tell you anything is that a good greeting went out well, a great greeting that probe do you say or where is it placed?
11 years 8 months before #43655 by manual-mecanica
The engine change is already underway, I have the gearbox and some support, I have to change the collectors and the injectors, do the Renault injectors go well? Any recommendation to get them?
11 years 7 months before #43817 by manual-mecanica
Well I have not needed to change the injectors, it has started without problems, uhmm one thing, I have a doubt of a dough that I have placed and I think it is not right, I have put the mass of the electro fans in the gearbox, but I do not see where it is put? Is it a mass that leaves the electro fan cables? Can someone help me? In a TAFFIC, VIVARO or CREAMSAR. . .
