A SAVE LIVES PLEASE !!!!!
11 years 8 months before #43660 by manual-mecanica
A SAVE LIVES PLEASE !!!!! Posted by manual-mecanica
Hello friends, I have a serious problem with a Citroen Berlingo 1.6 HDI 16V (Gasoil); Eta entered my workshop with the engine hitting a connecting rod, it was completely disarmed and repair of crankshaft it was placed new and injectors it was armed and in three motor turns I started until that time everything good but this cuano took it to try the damn had no strength after delay This runs out of force as if the turbine does not breach. The EGR valbule was annulled, the distribution strap was well controlled, the valbule bumps were changed, the scanning was the pressure of the turbine, the injection flow was controlled, the catalyst was taken out, in short, the very unfortunate solutions do not want to leave my workshop so I ask for your help. All limit is received in a good way thank you !!!
11 years 8 months before #43691 by manual-mecanica
Manual-Mecanica Answer on the subject A SAVES LIVES PLEASE !!!!!
FRIEND WILL NOT THAT THE CLUTCH DBATED THAT POSSIBILITY? It is very rare what happens to you because with all the points you checked and if they are well, I should work perfectly, tell us how you go cordial greetings. Jorge :)
11 years 8 months before #43742 by manual-mecanica
If you smoke, check the valves and empty hoses.
Try also taking the thermostat, to see if you have a direct relationship with the temperature, disconnect the temperature sensor, to see if the computer is blocking, to interpret some danger.
