Please help GMC Safari 99 alternator
11 years 8 months before #43784 by manual-mecanica
Please help GMC Safari 99 alternator published by Manual-Mecanica
On the needle of the Volt Board of a GMC Safari 99 marks as 9 volts must have the alternator to check with an electric and told me that it is good if you are loading and when you open the key if you mark the foquito of the battery and when it turns it on it goes out but the volts of the board does not mark me as it should be thanks ...
11 years 7 months before #43792 by manual-mecanica
Manual-Mecanica Answer on the subject Help GMC Safari 99 alternator
It is easy, check with a multimeter if you are really loading, if it is above 13.2v then it is loading, and what does not work is the engine of the board
