- Thanks received: 1
06-19-2025 Hits: 666 Technology
You have the torque data and how to torque.Mov1973 wrote: Hi, as the friend says, it is not only the Board of Cuatura but the plane of it that spoiled a rectified will help you with the subject. In this type of engines in most cases it has been to "fill" with aluminum welding because of the low space between the water ducts and the "seat" of the firewall of the joint, which is where you have the leakage of the refrigerant towards the cylinders and that it is the one that you see that it comes out by the escape ... eye with the torque that you give to the creek bolts. luck
