KITED KEY BATTERY CONSUMPTION
11 years 6 months before #44474 by manual-mecanica
KITADA KEY BATTERY CONSUMPTION PUBLISHED BY MANUAL-MECANICA
wave. Tube Kita La Battery A Tienpo to Cabio the Board of a Rover 214. When it connects it, the thermal luneral without intermittent way was turned on ... as I go out I did not give importance. But soon I kEDE ME BATTERY Buy the keyless fuses and consume the front and rear fog. Alien could bake x where does the problem be? thank you
11 years 6 months before #44498 by manual-mecanica
Manual-Mecanica Response on the topic Battery consumption with KITA KEY
When the car is starting, nothing fails
11 years 6 months before #44499 by manual-mecanica
Hi Nowel, I think that the battery has been able to be stopped, and if I was already lazy, then I would need to load in conditions or put another. As I suppose, you will have reviewed that there is no positive peeled making mass. An important point of derivation is the starter engine in poor condition, but I do not think it is your case, the antinieblas, check your wiring and these, disconnect them and check to see if it continues to consume ... greetings !!
