Pitid and light in command box
11 years 5 months before - 11 years 5 months before #44646 by manual-mecanica
beep and light in command box published by Manual-Mecanica
Good, I have a Seat Ibiza 1.9 SDI Stalla of 98, of which it has a lithium screen. A few days ago, a beep began to sound at the same time that light is turned on in the control picture of a sign of admiration between kinship, go the hand ferno.
The whistle sounds when I give a curve or park it in Cuesta.
What can be?
Last edition: 11 years 5 months before by .
11 years 5 months before #44647 by manual-mecanica
Manual-Mecanica response on the topic beep and light in command box
Hello atodos, Rollerli reviews the brake fluid level, if it is under the minimum level the instrument box warns you with an acoustic signal and the witness of the brake system is turned on. If the level is low, Chekea Liquid leaks by the wheels and tell us. Cordial Sales to all.
11 years 5 months before #44649 by manual-mecanica
Ok, I will continue your advice and I tell you. thank you
11 years 5 months before #44654 by manual-mecanica
Hello Rollerli, as the fellow Fiat147, the brake level, and check leaks, that you will not find leaks, it may be that the level has dropped due to excessive wear of pills and brake discs, and, also, in some cases, it carries a button on the handbrake, sometimes it does not make it well contact when you lower it and it is turned on when you want, in your case, in your case it seems to be the case. greetings!!
