BMW 320 D E46 alternative problems
11 years 5 months before #44910 by manual-mecanica
BMW 320 D E46 alternative problems published by Manual-Mecanica
Good morning, I have an alternator problem BMW 320. Monte two years ago one of exchange, I got a battery light lowered it and cleaning it and drying it in a month. I put another and hard 10 km. Each alternator who puts shortly begins to blink the battery light until it is fixed and without producing.
I need some indication where the subject can go.
Greetings
11 years 5 months before #44911 by manual-mecanica
Manual-Mecanica Response on the topic BMW 320 D E46 alternative problems
Hi Pacorral, I would review the Escobillas of the alternator to see that they are not spent, also re -apprehend the diode bridge, and its wiring, not rule out a starter motor problem that is deriving the battery to dough. Greetings!!
11 years 5 months before - 11 years 5 months before #44913 by manual-mecanica
Hello everyone, Pacorral, according to what you expresses in your post, each alternator that places in the car fails, therefore my opinion is that it should not be the internal problem of the alternator. From my experience in BMW, I recommend checking connections to mass or ground to chassis. If this mass is not correct the temperature of the alternator, it rises more than recommendable and failures are produced early. The other thing I have observed are problems with the installation of audio amplifiers, etc., a lot of consumption. Many times this excess of electrical consumption also affects the alternator, generating excess heat in this, apart from that it already heats up when they are behind the radiators. Additionally, do I recommend checking connections to the battery to the chassis. Ultimate do you have problems with the starting engine? According to what I have observed when in these cars when there are problems of detribation to mass of the starter engine, problems occur in this (that is, the arane engine fails when using it) and/or the battery is discharged quickly, however reading to stop its post its post I do not see symptoms of starter engine, or battery discharge. It will be recommended to clarify this point and thus be able to help you. Greetings cordials.
Last edition: 11 years 5 months before by .
11 years 4 months before #45305 by manual-mecanica
Hello everyone, forgive to take so long to respond. I have looked at all the masses and electrical connections outside alternator and apparently they are correct. The starter engine does not fail and the battery is not downloaded. In the end I have put another alternator and in these two weeks it seems that there is no problem ... for the moment.
I will tell.
Greetings to all
