Wind from the oil level rod.
11 years 5 months before - 11 years 5 months before #45005 by manual-mecanica
Wind from the oil level rod. Posted by manual-mecanica
Estimated I am new in this forum and I have a Luv D-Max 2007 truck, 120 thousand km and when lifting the oil indicator rod it is as it blows, they consult them if this is serious or normal ???
Last edition: 11 years 5 months before by .
11 years 5 months before #45010 by manual-mecanica
Manual-mecanica response on the subject comes from the Oil Level rod.
You have to do a cylinder escape test. Because most likely it has a problem in the engine rings
11 years 5 months before #45014 by manual-mecanica
Hello, it is true what Jotabad says, this may be due to the kmts that the engine already has, if not much that "blows", it is even normal, well it is that Midas Compression. Greetings!!
11 years 5 months before #45031 by manual-mecanica
I agree with them, what I would do is buy an aditibo metallube boat for oil. If any segment of the cylinders is stuck or there is wear that product that I tell you Marabillas. That or you spend € 2,000 to disassemble engine and new segments.
11 years 5 months before #45039 by manual-mecanica
My dear friend do not worry too fast, first observe whether the pressure that comes out of the tube of the rod is dim or very strong to the degree of splash People, it is true that the compression increases but the oil expense never removed it.
If your engine is fine, take care of it when I require it and change your oil every 5,000km and it will last what you don't even imagine.
Note If you want to add a motor restorer will venephicate, greetings from Mexico Puebla.
