The renalt 18 2 liters is good?
11 years 5 months before #45034 by manual-mecanica
The renalt 18 2 liters is good? Posted by manual-mecanica
hello everyone. I am about to buy a Renault 18 Motor 2000 Model 1989. My question is that if they have many heating problems and because if so, many people who are problematic told me. I await an answer .. thank you very much very good page.
11 years 5 months before #45037 by manual-mecanica
Manual-Mecanica response on the subject The renalt 18 2 liters is good?
Hello, you have to periodically change the valve that activates the electrors more or less every 80,000 km and that the system is working airtight tries to place a witness light on the board when the electro fans are activated so that you can control the cooling system-Salujos
11 years 5 months before #45038 by manual-mecanica
Hello, the car on the route is good, I stepped on at 160km/h balanced and aligned and it is not trembling at all, good direction, in temperature a good purge well coolant and clean radiator the car does not heat it is right of the bulb you can put another one that activates with a lower temperature I think it was one of 504 to 82 ° C I do not remember
greetings.
11 years 5 months before #45041 by manual-mecanica
Hello Buffo500, I only who can tell you about R18, that these engines are "for a lifetime" of hard ones, but against this car, I will tell you that they spend a lot, too much; Take it into account. Greetings!!
