Astra
11 years 5 months before #45092 by manual-mecanica
Astra published by Manual-Mecanica
Hi, I have an astra 2.4 model 2004 and the problem is that when I go at a high speed, a sombid is heard in the engine does not fail so far it is only the one you have ... that it can work it ...
11 years 5 months before #45094 by manual-mecanica
Manual-Mecanica Response on the Astra
It can be some bearing, water pump, alternator, and even the tensioner of the distribution strap, disconnects the accessory strap and test to see if it disappears, tell us how you go, cordial greetings. :)
11 years 5 months before #45100 by manual-mecanica
It can also be a whistle produced by air entrance, eg. If the front of the front has some broken, etc. .. but as the fellow Jal tells you, it is usually a thing of bearings, but when it is one of these, you can also hear it accelerating it with the car stopped, on the side of the distribution. Greetings!
11 years 5 months before #45103 by manual-mecanica
Greetings:
I agree with the classmates, in the event that it was the distribution (time) buys the original band and pulleys, I tell you from my own experience .
