Kia Sportage 2000 is accelerated
11 years 6 months before #45175 by manual-mecanica
Kia Sportage 2000 is accelerated published by Manual-Mecanica
How about colleagues, I need your help I have a Kia Sportage Model 2000 and the problem you have is that you stay accelerated when you step on the clutch to make the change does not lower the rpm if anyone has had a similar case with a car of these and has solved it I appreciate the information they give me.
11 years 6 months before #45176 by manual-mecanica
Manual-Mecanica response on the subject Kia Sportage 2000 is accelerated
Hi Roy85, such as several things, you should check if the IAC works well (not to grab), the TPS, which recognizes the slowdown state (contactor with closed butterfly butter), that the fuel regulator works well (which is not closed) measure pressure on ramp ... as guidance in case it could serve you. Greetings!!
