Kia Rio 5 radiator fan does not work
11 years 5 months before #45177 by manual-mecanica
Kia Rio 5 radiator fan published by Manual-Mecanica
Estimated does not work for the fan, I realized why the radiator is broken, the theme is fixed by the radiator and the mechanic told me that I was going to work, which does not happen who can help me
11 years 5 months before #45179 by manual-mecanica
Manual-Mecanica response on the subject does not work Kia Rio 5 radiator fan
Start by checking the fuse, then if you get current to the fan, if not, check the Refigigrante Relay and temperature probe, this last command the function of turning on the fan. It would not be more than for security you would look at the water thermostat.
11 years 5 months before #45180 by manual-mecanica
Thanks, I will
